Deep subject.
calling all hackers, geeks, and such
Need help with computer
Spent the past week putting a pump, pressure tank and well house on my property. First pump out was murky, second was clean, and third was crystal clear and cold! On the first recovery I got about 3/4 GPM, second was 1. 5, and the third was under the pressure tank and I couldn't pump it out through a 3/4" hose.
Looks like a good well! Got my septic tank in. Next is the shop. Then the house! Really worked my Cummins last week, hauling Fifthwheel, car trailer, equipment, and many runs up and down the 17 miles of dirt to and from the property. Have to love it... ... ... ... ... .
I am a little behind you on the well as I have only had the well drilled, but still need to pump installed. :(
I have pulled permits for the septic system. :D
Then the Garage is next! Oo. :D One of them big honkers... .
Good luck with you property... .
Put it in.
Put my pump in myself, not that bad. Go to pumpworld.com
and check out there package deals. Just don't trust their instructions. they were calling for pitless adapter hole in the casing to be 1-3/4", should have been 1-7/8" . It took me about two hours to file the hole out. And the 80 gal pressure tank will not allow for enough room to put the pressure switch on. Had to put about four inches of nipple to gain enough room. But really didn't take much getting it in the well, me and my wife had it in within twenty minutes after set up.
I am hopeing for a NO cave situation Doc... ... ... ...
