The Supertech/Wally World stuff has an actual, legible date on it. No secret decoder ring, or enigma machine required. At least what I saw locally.I really like goimg to truck stops for my def, could never figure out the box code so stop buying the box.
Either way, if you suspect anything, or just want to spot check, I suggest you throw one of these under the back seat.
https://www.otctools.com/products/otc-def-refractometer
Very easy to use. It won’t check for oil contamination (not a issue with store bought) but will check concentration (very real issue regardless of source).
I have both. Put some DEF on your coolant one, if it’s graded for specific gravity, it should be right at 1310. That’ll be 32.5%.I have been using that to check my antifreeze for years. A very handy tool.
Without pulling it out and looking at the paperwork to see what all it measures I know it's antifreeze and lead acid batteries. Never could bring myself to do batteries as it just does not seem right to put acid on a tool intentionally.I have both. Put some DEF on your coolant one, if it’s graded for specific gravity, it should be right at 1310. That’ll be 32.5%.
It's like using a pressure gauge on a calcium filled tire. Destruction is inevitable.Without pulling it out and looking at the paperwork to see what all it measures I know it's antifreeze and lead acid batteries. Never could bring myself to do batteries as it just does not seem right to put acid on a tool intentionally.![]()
I do all the time, check levels monthly. I have a temp adjusted battery hydrometer same as I used in the USAF to test.The idea is to measure the specific gravity of the electrolyte. Just a drop on the lens, and cleaning up with quick wipe with a wet paper towel when you’re done will go far in protecting the tool, but who checks battery water any more?
Is the DEF quality from gas station pumps good enough vs buying the 2.5 gallon jugs in a auto parts store. I think I have one where the def is 2.75/gallon which is about half the cost of some store bought jugs.
Until now, I've always bought from gas stations thinking that the DEF was more fresh. Over the labor day weekend, I stopped for DEF and right after got a Service DEF warning. Pulled the code when I got home and it was a reductant quality error code. I think it was P207F. Drained the DEF and refilled with new from a box (approx 2 months old based on the date code). Error code cleared and now the truck is fine.
Never getting it from a truck stop again.
