Ok, def gauge went to zero yesterday. Restarted truck today working then to zero again with full Def tank. Drove straight to dealer to show them. scan showed low def fluid trigger and a def sensor issue that tech said was a bad sensor.
I then read that there may be some sensors that get clogged and can be removed and cleaned but is this the type I have in my 2017 3500?
Also, need to drive kids across a couple states to baseball tournament next week and was concerned that with gauge at zero and the little yellow light coming on that even if my countdown indicator not on yet that I would get stranded with the truck thinking I was out of DEF. Mechanic at shop said as long as full and flowing this would not happen but that would mean there is another type of sensor to tell the truck to shut down if you are following me and I am not so sure about that.
Does anyone know that if they cant replace sensor in time can I drive as long as fluid in the tank with a bad sensor without going into limp mode?
