defective freeze plugs on 2004.5's ?
ISB 305 torque
NV5600 Notchy shifting and brass in the oil?
has anyone with a 2004. 5 heard anything about leaking freeze plugs on the blocks?My dealer on last oil change showed me a bulletin from DC to check the block for leaks on the plugs. They hold the engine at max power for 3 minutes to do the check. we have a 2500(was checked no leaks)also a 2004. 5 3500. Is this check to be done on all 2004. 5 engines?
There is a TSB on this that was discussed a bunch last spring or early fall. Many of had the test done with no negative consequences and no problems found. Negative persperation.
