Engine/Transmission (1998.5 - 2002) defueling problem?
Engine/Transmission (1998.5 - 2002) It's getting annoying
2nd Gen Non-Engine/Transmission allgnment after balljoints
we'll need more info. fill in your sig. year of truck,mods,when does it defuel? what settings? do you have good fuel pressure when defueling?
sorry im new to this. dont no how to fill in sig. so here it is. 00qc lb fass 150,4"turbo back, juice with att, smarty, arc flo with custom cold air, afe air filter. edge works fine with smarty off but when smarty on every thing works good unless edge is on 6th stage.
do you have a fuel pressure gauge or light? Also, what setting is smarty on? juice adds timing and smarty odd numbers do too, so you cant run odd smarty #s with juice.
go to the top of the screen put cursor on " discussion forums" a menu will appear, click on "user control panel" look to the left of the screen you'll see a column with "edit signature" click it and it will bring you to the page.
i new bout the double timing nono. i set the smarty on #8 an it defueled so i took it off an double checked my edge an it worked fine. i put smarty back on an put it at #6 an it still defuels. juice displays fuel presure an shows it to have plenty
thats dumb. thanks 4 the help. also curious bout the ecm options. it shows timing,torgue an duration. not sure what to do with that. dosent talk bout it in the book. dose it mater how many times u remove an install the smarty? thanks again.
