I have NO experience with lifts at all. I just put a Skyjacker softride 4" lift front and 2" lift rear (2" blocks with 6" springs). It looks like the front skyjackers had an aluminum degree shim that got semimangled when the parts truck ate a Lumina. About 1/4 of the shim is missing on the narrow corner. Do I need the shims? What degree of shimming do you usually use for a 4" front lift?
Also, What about the rear bumpstops? They used to hit the 6" factory blocks. Do I need to lower the bump stop 6-8" now??
I used the 4" drop Pitman arm and adjustable drag link too.
TIA
Ken
TIA
Ken
