Deleting the EGR but keeping the DPF? possible?
P2262 revisited
Fuel Mileage Dropped After New Computer
Can you remove the EGR stuff from the truck and just run the DPF? Do i need a tuner to do this? I just hate knowing that exhaust is going back into the intake!!
I am curious as well.
It will take a tuner to be code free, but I am wondering if there is a tuner that disables the EGR but leaves the DPF intact. This would be a much easier way to pass visuals and keep the intake/turbo a lot cleaner.
May be possible with something like efi live or similar. I think they can turn the egr off. I can't see why not the dpf can run without egr.
My EGR cooler went out over 100,000 miles ago and was never replaced. I yanked the EGR hardware, made plates to cover the holes and moved on. The original DPF is still working great with about 290,000 miles on the truck. I have a constant CEL due to the deleted EGR system which I think a tuner will clear but I'm not about to spend that kind of money just to clear a CEL. If you dont mind the CEL being on then all you need are some blanking plates. The DPF doesn't care.
Edktrans: I'll make sure my friends know that. They don't like the idea of soot put back into their engines
The early Smarty boxes running non-delete software turned off the EGR system along with adjusting the timing and fuel. I don't know how to prove this, but that was the info I got from a couple good sources when I bought my Jr and Sr programmers
