Delivery Valves? Do I need em?
Temp gauge flucuation?
Injectors??
I installed 370 injectors a while back. The truck runs stronger than before. It originally had the 180 injectors. Would I benefit if I installed larger delivery valves? If so, how much of an increase in power would I realize?
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other governor modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer, ATS Exhaust Manifold, Psychotty Air Induction, BD Exhaust Brake
By doing the bigger nozzles, you are now asking the injection pump to flow more fuel than the stock delivery valves can deliver. This will cause a "canning" sound in the exhaust at part throttle and is due to the nozzles getting an uneven pulse of fuel. This will be totally overcome by the bigger delivery valves and power-wise, it will give you a broader band of power across all RPMs.
Chris Timochko
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission.
Well dang, maybe thats the knocking sound that I've been chasing. How much power gain is to be had with the bigger delivery valves over the stock 180's?
What I experienced in installing the 370 nozzles was a torque spike at about 1800 rpm that would cause the rear wheels to explosively spin in third gear. Doing the delivery valves effectively smoothed out this torque spike and gave the engine an overall increase in power across the entire rpm band.
Chris Timochko
Sounds like a winner to me. The engine does not currently have the miss at 1100 rpm that some have talked about but I could use more torque. I still have not broke anything so I guess I don't have enough yet #ad
Which kind of delivery valves is recommended for my set up?
Am I correct in recalling that the delivery valves are not as important when going from the 215's to 370's?
Would the cost be worth the difference?
97'3500 SLT CC,4x4,5 spd,4. 10,94k,EBY aluminum flatbed,Dee Zee running boards,Dee Zee Platinum drop boxes,Mag-Hytec,BD Brake,Pyscotty,Jardine 4",Geno's monster tip,TST plate,370's,AFC, ATS, Bilstein,Isspro,PIAA Superwhites,Tekonsha Sentinel
dieselburner,
I don't know the answer on the delivery valves, but hopefully Joe Donnelley will step in here and give us the scoop. I'd like to know as well..... just ordered the 370's #ad
for my poor underpowered Ram.
What is the HP rating on your #4 plate? TIA
1997 2500 Ext Cab 4X4,5 spd,3. 54's,Pac brake,Rancho 9000's,Centerforce clutch,K&N airfilter,Missing
Cat,Isspro gauges,TST #11 plate (280hp/680tq),AFC medium spring and Jardine 4" exh.
Originally posted by DieselB59:
... a torque spike at about 1800 rpm that would cause the rear wheels to explosively spin in third gear.
d@mn , don't you just hate it when that happens? #ad
Pete
[This message has been edited by pcorssmit (edited 01-16-2001). ]
The 160 hp pump needs the bigger delivery valves with 370 marine injectors. The higher hp pumps can benefit some, but it is not essential. I haven't done a back-to-back dyno test with the 215 pump but I expect with the bigger pumps the major gain is in driveability, not maximum hp.
For what it's worth, when my pump was out
and being warmed over, this question came up. The answer was that I didn't need them. The stock pump, (in a warmed over state) can handle the 370's with no problem.
And I can atest to the fact that my truck has an even throttle from when the boost comes on to redline. (my fuel bills show it too!!!) Just way too much fun... ... ...
I know I might get hammered for this posting but what the heck, everybody should be able to hear all the info available.
Right?? :), Maybe I just have a ABBY-NORMAL
truck.....
97 2500, extcab, 4x4. BFG 285/85/16 AT, "warmed over" pump, JRE Stage III plate, AFC spring kit, BD gov. spring seats only, 370 injectors, K&N, 4" Edwards Exhaust with Dynomax straight through racing muffler & 5"tip, (Cat got "lost"), EGT, boost, oil & transmission temp. gages, Low Stall torque conv. & BD valve body, silencer ring "exiled", Grover Emergency air horn and a multitude of strobe lights and switches (Vol. firefighter)
Ok Joe just what kind of driveability improvement are you talking about. The only thing I have noticed since the addition of the 370 HP injectors is a touchy throttle. A little throttle = more than it ever did before. #ad
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, Rad fan removed, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, Dyno'd 342 HP pre injectors & turbo housing *NRA/USPSA member and proud of it*
[/B]
I don't know what the plate is rated at. It is hotter than the #5 which I traded back to Mark at TST #ad
. It does develop noticeably more torque than the #5 plate and fuel comes on earlier in the rpm range. Mark at TST could fill you in on the rating if there is one now. At the time that I got the plate it was experimental and had no rating.
Bringing the question on driveability and delivery valves back to the top.
Joseph Donnelly,
You mentioned that "with the bigger pumps the major gain is in driveability, not maximum hp". Could you please elaborate on the "driveability" in this context with the BIG 370 INJECTORS. I'm trying to decide if I should go ahead and get the 'proper' delivery valves. I believe DieselB59 mentioned a torque spike at around 1800 rpm. Is this the same driveability issue you mentioned? TIA
[This message has been edited by R. ebel (edited 01-17-2001). ]
The main diveability issue is a stumble around 1100-1200 rpm, kind of like a roughness or loading up from a big camshaft and dirty spark plugs in a gasser. Piers is out this week but check with him next week. He came up with these delivery valves, as with so many other toys we now enjoy #ad
Joe, Sickly and my truck don't seem to have this stumble at least I haven't noticed it. Is this a some do and some don't thing?
Here is the e-mail that I received from Piers on the delivery valve issue. I had sent him an enquiry to his home e-mail when I found out he was off this week. No rest for the wicked Piers! Thanks for the info if your following this.
Hi Steve,
Do you need the delivery valves... no, will they add more hp... yes
part# 1040180
We have sockets that one can buy or borrow, it's up to you.
Piers
----- Original Message -----
> Hi Piers,
> We met down in Tulare at the tractor pulls. How are you doing? I have
> the 370 injectors
> installed in my 98 12V. It came with the 180HP rating even
> though it's a 5 spd because it is a CA
> engine. I have a #4 plate installed along with a few other
> goodies. You could see my signature on the TDR under "Delivery Valves do
> I need em?". The engine does not have the stumble at 1100 rpm that some
> people have. Should I also replace the
> delivery valves with this application and will it give me more
> power? I still haven't gotten around to dropping the linkage on the
> side of the pump to get the part number. Do you still need that
> info? I can probably do it today if you do. I've got the day off. I
> talked to the pump guy at BD but he said that I should talk to you about
> the performance applications. If you reccomend that I should get them,
> can you give me the part number so that I can get the right ones from
> BD? I will also need the spline socket. Can I order that at BD too?
> Thanks.
> Steve
