Dexter Axle's Heavy Duty Suspension Kit Install
Max Brake - Tuson w/direct link
Thanks for the advice
I was looking over my 5th wheel and I noticed I could see the bolt hole in one of the hangers. So after some looking on the Internet I found this kit from Dexter Axle(K71-449-00 Heavy Duty Suspension Kit for 1 3/4 leaf springs) . It replaces the bolts with ones that you can grease, the equalizer which you also grease, the hangers are twice as thick, and the plastic bushings with bronze ones. Installation was straight foreword so I won't bother you guys with that but here are some pictures.
Oh ya I almost forgot. While I was breaking everything loose I thought I should put some gloves on. I said to myself I'll be fine. Two seconds later... ... So here is something for your guys Safety Meeting tomorrow. Had to drill the poor thing... . LOL live and learn or maybe just live.
WOW!! That hurts just looking at the photo of your finger:eek:... been there done that too many times. At my old age, I've finally learned:-laf... wear gloves! Mechanic's gloves are in my tool box where I can easily grab them before I start a job.
Yep, I've done the Dexter suspension upgrade to two different 5th wheels.
Bill
Wow, those shackles are heavy duty, good pics, thanks. Yup, I wear gloves all the time too, it don't cure all but it sure helps!
Nick
Hey, you have the same "pick you in the back", "drop a nut and can't find it" rocks in your yard that I do. :D:D
Mike. :)
At least he could LOOK FOR THE NUT!!!!!! I haven't seen MY ROCKS SENCE LAST OCTOBER :-laf
PS I KNOW WHAT YOUR ABOUT TO SAY ha ha Ya and its been that cold lately also. I would have turned the grease nipples to the inside it easy to climb under than have to take off a wheel to grease the bolts. Hope it works out for ya As far as your finger BIG DEAL YOU HAVE 9 OTHERS TO PICK YOUR NOSE WITH :-laf Gloves??? do they stop you from smashing your finger or just hide the fact that your finger is now FLAT
BIG
BIG
Nope, gloves don't prevent me smashing my finger, but it does soften the blow a bit and it takes longer for the blood to appear... it has to soak through the glove while I groan in pain and swear at my finger for being in the way!
Bill
My helper and best friend during the years I farmed would say: "Boy!! If you would do that to your OWN finger, what WOULD you do to mine!! Then a short laugh and big smile! Pearlie Leonard was a man's man, mentally tough, no education but "uncommon" sense, a champion, a Christian. I think about him every day!
