"Hitch:
The hitch must be a "Reese"-style hitch; reinforcements are permitted. Trick hitches are prohibited. The hooking point
must be the rear-most point on the vehicle. The hitch must be horizontal to the ground and stationary in all directions.
The hitch's height from the ground may not exceed 26 inches. The hooking point must have a minimum 3. 00 inch inside
diameter opening for the sled hook. The hooking point will be measured to the center of the clevis loop. "
Been getting alot of questions on this part:"The hooking point
must be the rear-most point on the vehicle. "
The rear most point of the vehicle is considered the stock location of the tailgate. If the tailgate is removed, the hitching point STILL must be where the tailgate would have been.
Rear bumper: If the rear bumper is on the truck, the bumper will be the rear most point of the truck. However, if the bumpers' center is cut out, leaving safe access for the hooker, then the tailgate will still be the rear most point.
Removal of the bumper is allowed, and "sled bumpers" can be installed, as long as they do not interfere with safe access to the hitching point by the hooker, the tailgate will remain the rearmost point of the vehicle.
Next item: "The hooking point must have a minimum 3. 00 inch inside
diameter opening for the sled hook. "
I highly suggest you make sure the hook fits your hitch before you pull onto the track at IRP.
Also, farm clevises with the 8" drop hollow ball mount turned upside down, really need to be phased out. Whats the weight rating on them rightside up? 400#? Think about it.
If you are pulling anything with more power than stock, you need to build/purchase a proper hitch.
DHRA Diesel Nationals at IRP-18 days away!!!
