zstroken said:Street class. If they allow dual CP3's heck they might as well not eliminate the RPM limit. When I mention that street class, and it should be stock appearing, the GM boys say "just limit it with the turbo" So if that is the case, just limit it with the turbo, let the open RPM limit stay. If you want more fuel, go buy a modded CP3
JFaulkner said:Your not doubling the amount of fuel being injected, your only keeping it atomized.
cause if he had enough money to put two ppumps on the engine he probably has a lot more in the rest of the truck.
zstroken said:. If somebody came up with 2 Ppumps on an engine and he will probably win, why?? cause if he had enough money to put two ppumps on the engine he probably has a lot more in the rest of the truck.
mfunderburgh said:Have you priced a set of dual cp3's? I had 3 times the amount of money in just a good cam for my cummins as what i can build myself a set of twin cp3's for. So if a truck now has a fancy paint job we probably should assume he has too much money in the motor too?
Diesel Power said:how do you like your PPE edge juice stack?
quit trying to have the rules written to keep old mechanical motors on top.
