Steve, when I installed what is now my spare lift pump, pressure readings where a solid 14-15 psi inlet and 15-16 psi outlet. I watched as the pressure readings dropped as the LP aged and the readings pretty much always stayed the same relative to each other, until last summer when I started noticing a 2 psi drop at the inlet reading. It is now always 4 psi lower at inlet than at outlet. I swapped the senders and still the same. I think I'm going to go with two mechanical gauges as I think my senders are probably bad. If, as Bill said(another thread), electrical senders tend to be a problem on diesel's, I want to eliminate another regular maintenance item in the fuel system. The LP's are bad enough.
And to echo the sentiments from above: I really like the cockpit look with all of those gauges.
