Di-Pricol gauges
Newby needs Edge and Bully Dog advice
2004 Dodge Cummins HO
Genos hands down. They're EGT gauge is almost 30 bucks cheaper than the closest competitor, and up to 60 bucks cheaper than many.
Mark,
What are your sources? I find it a little hard to believe that hacking off a plastic grab handle would have any significant effect on the "crash worthyness" of the truck.
On the lighter side of the issue, I am the only driver of the truck, so if I wreck and injure myself are they going to arrest me for it. Doing stupid things and hurting or killing oneself is a southern tradition.
"Here, hold my beer and watch this..... "
Fireman
My understanding is that you cannot put anything on the A-pillars if you have the side air bags. So it will be the dual column mount for me unless something better turns up.
I want to go with the Di-pricol gauges also, but would like to have boost, pyro and transmission temp. and would obviously have only 2 spots with the dual column mount. Westach dual gauges would solve that problem, but are a little busy for me, and the dash match isn't nearly as good.
Anyone know if there is room between/behind the heated seat switchs where the 2 blanks are on the Laramie for a gauge?:confused:
I think I'm good-to-go with the wife on getting gauges. I told her when she first started driving my truck that she needed to let it idle down to cool off the turbo. Her response was "Why didn't they put a light or gauge on the truck so you knew when it was cool". Gotta love the way she thinks. ;)
I have side air bags, I decided to go with the X-Monitor: Trans temp, Pyro and Boost.
They are more expensive but hopefully worth it. :rolleyes:
We have single, dual and triple Di-Pricol gauge sets complete with all the items needed for installation including colored pillar mounts, wiring etc. We also have the Di-Pricol gauges for the new Dodge with black or chrome bezels.
I checked out the A-pillar/Side airbag controversy before I installed mine and was told by Geno's that the problem was with GM's setup, and that ours was okay. Call Andy at Geno's.
Dean
pod/airbag issue
I just got a pod from Geno's and in the instructions, it said not to use it with the A pillar airbags. Are they meaning the side curtain ones? how far forward do the airbags deploy? I really want the A pillar pod but not if it could kill me.
I had the same concerns when I read that and I called Andy at Geno's as I stated in the previous post. Some of the side airbag installations use the A-pillar, Dodge doesn't and it is not a concern. Call Andy at Geno's.
Dean
