Di-Procol EGT & SRT-10 Problems
Is there a way to tell what weight oil the dealer used???
Installing a Super B2 on my 05 Today
I'm getting ready to install my Di-Procol EGT in my SRT-10 pillar but I can't get the plastic "clamp" to go on correctly. It looks like it's hitting at the bottom of the gauge hole and I can't get it to tighten correctly. Anyone care to explain what I'm doing wrong?
When I installed my dipricols, I didnt use any clamps. The fit was tight enough that I was able to just slide it in, and it hasent moved in about 4 months. I figured that it will be easier to change a bulb if I have to. Of course this was on a 2 pod pillar. Not sure if the fit will be tight enough on the SRT pillar.
I had to file away part of the clamp to get it to clear the inside of the pillar. I removed the flare at the end of the clamp where it interferes. Still a bit of a tight fit, but it worked for me.
Marc
Marc
I did the same thing, ended up with a real tight fit. I used some emery cloth, it removed the material pretty easy.
Bert
