Diablo Volumizer?
2000-2200 Rpm Vibe
Dynoed PowerMaxCR
Has any body heard of the new Diablo for the 03, it's called the Volumizer. Switch on the fly 0-60-100. Is it a timing and fuel or just a fuel chip? Know someone looking at one just wanted input.
Thanks Jared
Pretty much the same thing as the Bullydog Box, no timing just fuel pressure. It takes alot of fuel pressure to make the 100 hp that Diablo (PDQ) claims. Makes me wonder if it will cause the same thing as the early Duramax Boxes did, where they were raising pressure so much that they were blowing everythng past the o-rings, lots of fuel in case etc...
I dont know for sure if this will happen but, I have seen this happen with the GMC when pressures were raised to high. .
I am going to wait until something with timing and fuel pressure comes out. I know that edge will have a box with timing and fuel pressure out sometime near the end of the summer, and I believe that TST, Vanaaken, and Bullydog will have something out within the next month. .
Thats about all i know for now. . Hope it helps :D
I have a prototype Bullydog Box. It is as follows.
25 hp
90 hp/ fuel/timing is about 50/50
140 hp fuel/timing and a streched pulse.
Feels like Edge Drag Comp on level 3. Pulls hard all the way.
I quit keeping up with diablo after a while. They have a long history with gassers, but they APPEAR to be new with diesels. when I was truck shopping (for the past two years), I remember when the predator came out. The hype was incredible. They made the thing out to be a miracle box for the duramax. Shortly after that, release dates started to get delayed, and the diablo guys got real quiet about the product. Not sure what happened after that, I have up on those guys. The proof is in the puddin' you know... For my money, I'd stick with one of the guys that has been making these things for a while like Edge.
My . 02
/abg
Hey Jaman I think your wrong. The volumizer hooks up to the fuel, map, CAM, and CRANK sensors it DOES do timing. If you don't know what your talking about don't post misinformation is not fair to the tdr members or the company that makes and sells a product I'm not trying to give you a hard time but EVERYONE should be sure about the facts before they post
Sorry JaMan I ment to say voodoo3.
Should check the facts first not you... ... ... ... I guess I should learn to get my facts straight before I open my mouth too!! If only I could think as fast as I type. Sorry again JaMan
