diagnostic code readers/scanners
EGT - Pre or Post turbo?
South Bend Clutch "kudos"
Has anyone found a scan tool that can read the can bus info? I just purchased an AutoXray 3000 and although it claims to be CAN compliant - there is no firmware for it yet to support our trucks (this scan tool CANNOT scan the 2003 ISBE trucks correctly -you must use the Generic ODBII option -which is just about worthless) I'm also after transmission data as well- Primarily solenoid and lockup data) Other than a VERY expensive DRB tool -is there anything out there that can get to the data?
Interesting. I have an Actron OBD II reader for my Suburb and then bought the truck. I tried the scanner on the truck and it seemed to work fine. So are you saying you need something special to read the truck (with any scanner)?
