Thanks for the correction Bob. Fortunately I've never worked on a EGRed rig. I'll add 32 to the list. I noticed code 68 is also for the EGR. Here's the list again, I copied it from a post here and can't vouch for it's validity though. 32 isn't in my manual, and has different definitions in each of these different sites
http://www.obdii.com/codes.asp
http://autorepair.about.com/library/ts/bl-dtcs-main.htm
If you go by the OBD II codes by using the key off/on method you will have to use only the last two digits the other three are explained here
http://www.obdii.com/dtcanatomy.html
11 = no crank reference signal detected during engine cranking
12 = no codes. Problem with the battery connection. direct battery input to the PCM disconnected within the last 50 ignition key-on cycles.
15** = no vehicle speed sensor signal. No VSS signal detected by the PCM during driving conditions.
23** = intake air temp sensor voltage high or low. intake manifold air temp sensor circuit signals above or below the acceptable voltage.
24** = (TPS) voltage too high or low. Test throttle position sensor. 32 = EGR solenoid circuit failure (or, in CA, air/fuel ratio change not detected during diagnostic.
33 = air conditioner clutch relay circuit. an open or shorted condition detected in the air conditioning clutch relay circuit.
34 = open or shortened condition detected in the speed control vacuum or vent solenoid circuits.
37** = (TCC) solenoid circuit open or shortened
37** = trans temp sensor voltage too above or below acceptable voltage values
41** = problem with the charging system. When voltage from ASD relay is below 11. 75-volts.
42 = ASD control circuit indicates an open or shorted circuit condition.
44 = battery temp sensor volts malfunction. problem with bat temp voltage circuit in the PCM
45 = trans overdrive solenoid circuit malfunction.
46** = charging system voltage too high.
47** = charging system voltage too low. bat volts sense input below target charging voltage during engine operation and no significant change in voltage detected during active test of alternator output.
53 = internal PCM failure detected.
55 = COMPLETION OF FAULT CODE DISPLAY ON CHECK ENGINE LAMP. THIS IS THE END OF MESSAGE CODE.
63 = controller failure. EEPROM write denied. check the PCM.
68** = PCM not active or a fault condition to the EGR sensors and/or EGR solenoid
** = check engine light will come on with engine running if this code is thrown
