And low and behold, its a 6BT, NATURALLY ASPIRATED MOTOR!! It was a 55 block, with a VE Pump, rated at 96 HP, with KOMATSU badges in place of where the Cummins Serial Tag is. Kind of neat. . Instead of using some cheap Komatsu Filter, I slapped on a Motorcraft FL896, Approved for use by Cummins, so I know the motor is in good health now! The wierdest part was the Exhaust manifold... It looks like a typical 12 Valve manifold, but the end of it, curves up and just goes straight to pipe, rather than to a turbo. It would be sooooo easy to BOMB one of those little suckers! How cool would that be, having a hot rod Forklift?! It already can light up the tires!!
Have y'all ever seen a Cummins with a different name stamped on it? I know CASE does it, but any others??
-Chris-
-Chris-
