got a grease gun hose and a good mechanical gauge and checked my fuel pressure under the hood, I first put it in at the plug away from the motor (pre-filter I think) and got 16psi, then put it in the hole closest to the motor (post-filter I think) and had the same readings, both only dropped a few psi at WOT. I know this is not under a load but it seems the lift pump is working now. I left the guage attached under the hood where I can at least pop the hood and have some idea if there is pressure there or not. Does this sound OK?
