I did one of those "never do things". Couldn't sleep, got up at 03:30 and stumbled around a bit and decided to finish up ordering a couple of items.
Along with some other stuff, like a new VP44 from Midwest Fuel Injection (super nice folks by the way), I clicked on the Bosch 300 HP injectors.
Are those the same as the RV275's ?? My intent is to get better fuel economy and maybe a little more HP. Just enough hp to keep the transmission from doing that double shifting/hunting up/down that is so irritating.
The truck is bone stock except for a Dodge Hi-Performance ECM that came off of a 2000 stick shift truck. That ECM gave me a "seat-of-the-pants" 25 hp because the difference is noticable. It also has the Van Aakin module on it. Either of those two options seems to produce about the same results if used singly. Together, the truck seems to perform very acceptably for everyday use.
The truck is used for city driving 99% of the time. I pull a trailer maybe once or twice a year, and even then, it is casually and never in a hurry. I don't try to fly over hills with a load and downshift out of OD if the truck starts to bog down any. The travel trailer is a 1978 34' Avion @ 8,000# loaded 3-axle.
So, my question is. Did I get the right injectors for better everyday fuel economy? Will there be a downside or detrimental effect to the Bosch 300 hp injectors in a stock truck?
I am under the impression that I should install a boost elbow to let the turbo add more air to go with the bigger injectors to keep the EGTs under 1200. My reading lets me believe that the elbow should be adjusted for about 30 inches of boost. Is that the right value?
I don't want to be blowing up the transmission. No money in the budget to replace that, and with that in mind, I will not be a "full throttle" balls to the wall type of driver. never have been anyway.
I am installing a full set of gauges (thanks Genos), a new VP44 (all bad codes on mine, but still running) because of dead pedal, etc... and a new crank position sensor (just cause it's easy to get to now).
Genos sent me a Vulcan relocation kit so the lift pump is being moved to the tank. I would do away with the Carter pump, but I happen to have 3 brand new ones on hand.
Looking for some good insight here.
Thanks guys.
Thanks guys.
