I'm using a Genisys scanner and it'll let me into OBD2 mode but not OEM mode,no matter what,I've tried everything. I have the correct chip in the scanner for OEM mode and the connections are fine,it works perfect in OBD2. Did my ECM just take a *****?? It'll also set a grid heater b code(I have a new grid heater,it set the code before too) and an overboost code,all I have is a larger exhaust,K&N filter and 300 injectors. I have to stomp it pretty hard for the overboost code but it has a new MAP sensor and it shows up to 75iHG on the scanner,which I believe translates into around 18 lbs of boost,someone fine tune those figures if they're off. Also,what is the IAT failure rate? I've cleaned mine off before but according to one of Marco's articles from somewhere else it can still be out of range or not responsive enough,causing a weird or late fuel curve. Thanks...
