Archived Did my ECU die ??????
Archived sticking brakes!
Archived help me b-4 i spend the $$$$$$$$$
OK man what a day ok i was putting injs in and a turbo , i had to get inside the engine bay and holld this thing up with my feet (long story) now one thing i did was pull the grey connector from the - side of the Batt but it pluged back in , ok i turn on the key but no pump tried again nothing , so i turned it over couple of times nothing so i started checking fuses i found 1 bad replaced it still no pump i check power to the pump there was none so i swapped relays stilll nothing . So now i run a wire to a 10 amp fuse turn the key on and pump works , ok now my Redline keeps saying tps to low , witch it does some but goes away this time it wont ok so i turn it over and get the air out fuels coming out fine so tighten lines up turn it over nothing over and over nothing , OK now i plug my smarty in to read any codes but it wont connect keeps asking me to turn key off then on then on then off , it wont read my ECU so im thinking i must have pinched a wire or someting and fried the ECU any other ideas :confused: :confused:
