Details here: TDR Privileges
Have the 03 had any reported Lift Pump Troubles. Surely with over 15,000 Members there must be a few hundred 03 's driving around?/? How bout it Gang ? Any Pump troubles
When my 03 was new, I was seeing about 9. 5 PSI at idle. Now its dropped to 8 PSI at idle. Putting high flow bolts in seems to have arrested the downward spiral. I need to get a flow meter on the system to check my flow, and see if I've lost anything.
One thing is fo sure though: To get into the high power numbers (500 - 550 HP), we'll need a new lift to ensure the low pressure side of the CP3 doesn't run out of fuel.
