Did you do the pump linkage kit?
Drive Line Seals
Ok I got a big problem
I did some time ago & the throttle pressure got lots easier last week. Well, just towed & yep, the bucking is back. I think I've dropped a spring. I just checked & there are 2 springs, side by side in the linkage, none other.
Can you pls ck yours & see if there is a 3rd spring?
thanks
There is only one spring in the linkage kit. Did you check the spring that should be on the injection pump lever? Maybe that one broke or came off. I only have one spring on the throttle lever. Should one of those be on the injection pump (assuming that one is missing)?
Got only 2 radixr. They are connected together at each end & are actuated together. As you look @ the pump, these are lower than the throttle cable & the 'kinked' solid linkage. Is there another one?
Yes, there is another one at the rear of the pump and lower than the one(s) at the front of the pump. It is connected to the governor (?) lever at the rear of the pump below the AFC housing.
