This one is weird. About once every two months my truck will die after starting and running for about 5 seconds. It doesn't have to be cold to do this either. As a matter of fact, sometimes it's harder to start if it's warm or hot. So, I bought some fuel line for the return (if it's not that it should be replaced anyways) and found that the factory lines are attached to the metal with some sort of sleeve. Do I cut the sleeve, or is there some slick trick to undo the line? The lines feel fine, not soft or anything, so I kinda don't think that this is the problem, but it's a start. The overflow is going in soon also. This problem happens so seldom that it is hard to trace down. Thanks for any help
Dan.
Dan.
