Use DiElectric grease on/in wiring harness connectors. ESPECIALLY on/in connectors at the lower part of engine -- like the crankshaft position sensor and flywheel position sensor (lower front of engine).
I've always been a believer in doing this. Note that the factory harness has dielectric grease in the connectors.
The main point is to seal the connection from outside contaminants; most notably water but also dirt/dust.
It's my opinion that many of the spurious codes and random problems with aftermarket boxes are caused by contaminated or less then perfect wiring connections. Not only does the grease seal the plug; it enhances the connection surface.
