This is the 4th time ive compained about this and followed the advice from all the other threads ... How ever my truck still does this heres a recap . .
Stock Injectors
Fried ECM
Suncoast tripple disk , 5. 0 KDL , ProLoC VB
Got the ECM fixed and transmission work done the same day .....
Truck Drops in RPMs when put in D or R ,,,, Maginal but noticable way more than stock RPM drop .....
Went with Bosiuos 60HP injector alot worst ,,, OK when engines up to temp but when its below op temp it still died a few times ,,, minimal in R mostly in D ...
Went with Haisleys 160HP sticks now it about dies 9/10 times the other times its Sweet dont hardly drop at ALL .
People said its the Vp44 going out ... well VP44 went out ... New Vp44 and it still does it
People Said its the ECM ,it needed updated and the cold weather reflash ... I took it tot he dealer thsey said I had the new version with all the updates
People said that the pressure were too high in the transmission ... I took it to the shop and had them cranked down ... DIDnt change a thing
Now people are saying the TC is too tight ... called suncaost they want to change it from 1900 RPM stall to 300-400 Rpm higher ... then called them back to ask more quesations and they said they dont think it will work .
Just got off the phone with Jeff Garmons Cell and he said its the injector and changeing the stall isnt going to fix it he said I need to shim my injectors to pop off around 4000 in stead of 3000 like I think they are now
What the hell is going on here ??????
Do I yank the injectors the transmission or what ????
Help!
DM
Stock Injectors
Fried ECM
Help!
DM
