This is weird.
I've noticed that when I rev the engine up, the engine's sound changes DRAMATICALLY once the tach passes 2100rpm. It's like the timing is radically retarded at that point or something.
I've noticed the following:
1) It only happens when the engine is fully warmed up in warmer weather.
2) It only seems to do it in the first three gears of the six speed.
So that leads me to another question: does the ECM know which gear the truck is in when you have the six speed? I was wondering if maybe the ECM putzed with the timing in the first three gears to reduce torque output.
The other thing I noticed is that it didn't seem to do this with the EZ. But I haven't driven the truck with the EZ in warm weather in a while. My EZ is gone (sold it), so it's just running on the DD2s. WG is blocked.
Finally, I don't think anything at all is wrong. The engine runs better than it ever has, as far as smoothness goes. Power is always there, and it always starts right up with no problems (unlike last year!).
I believe it to be normal, but I'd still like to know what's going on that causes this normal behavior. It's like a switch is turned off right at 2100 rpm!! The engine totally changes sound, going from a diesel sound to just a whirring sound.
Any ideas? Marco?
Justin
Any ideas? Marco?
Justin
