Jay,
Item 3 on the same page is the one that places physical limitations on the guide pin travel. I would think that regardless of the fueling settings, that thing can only travel so far based on the reverse lever dimensions and the opposing cast/metal part.
I do wonder how far past the narrowest part of the cone neck the pin will travel, and if at that max point there is any degredation of efficiency.
Is the the throat of the cone that size for strenght reasons?? for pin limitation/efficiency reasons?? etc.
JLeonard,
I wonder if there is a 'general' process for tempering the more "common" metal(s) that would be used in making things like the cone. For example, I'm wondering if mild steel was used, and if so, is there a 'basic' tempering process that will accomodate mild steel and whatever is slightly above/below this material.
I'm pretty surprised that "tool steel" wasn't used for this item though, or at least something with a decent Rockwell rating to minimize wear. On the up side, I'd much rather wear the cone than the guide pin. I think I'd rather repalce the cone assembly than pull the pump apart just to get at that pin. .
Bob.
