I agree with a lot that has been said, but I think I may have a few useful comments.
First 400rwhp is obtainable with just electronics. At least it is now.
Adding a pusher pump only works to an extent with high horsepower. At 400rwhp it works fine but much over 475rwhp you start to run out of fuel again. We will have something to fix that soon. We are doing the final testing on it as we speak. If you go big power like 550's + then you need a lot of fuel help.
Also don't forget that fuel pressure and rail pressure are two different things, and fuel pressure (delivery pressure) doesn't always help on a common rail system.
Also with the addition of timing in our new electronics egt's are much much better.
We feel about 430-440rwhp is all the fuel system is worth for the most part. If you cram a large amount of air in with that ( read Twin Turbos) you can get almost 500 on the stock fuel system but it is hard on the high pressure pumps.
All in all I agree with keith! I think soon enough the common rail will suprise people with the numbers that are obtainable!
