Details here: TDR Privileges
Because diesel is basically an oil, and gas has light distillates that evaporate easily. Gasoline is designed to easily become a vapor in the combustion chamber to facilitate the spark combustion process.
Diesel also would not smoke in billowing clouds from your pipe if it was full of the distillates that gasoline has, what tragedy that would be (unless you mixed it with 2 cycle oil to help it "lube" correctly).
