Nelco
Hi guys,
I have a diesel fuel drip, just under drivers side foot well, where the frame starts to curve up.. It's coming out of what appears to be a return line that runs parallel with the supply line. This line looks like there is a piece of piece of fuel line covering this "transitional" piece of plastic fuel line that connects to what appears to be a quick-connect near the bottom of the lift pump. Beyond the quick connect, by feel, it seems to have perhaps a banjo bolt holding it on the far end with an affixed "brace".
I can't tell what is causing the drip (leak)...it only happens when running. Perhaps rust/corrosion? I can't figure the hard plastic line failed?
Before I go in deep, it would be good to have some background if possible.
2003 3500 SRW 52,000 miles
TIA.
N
TIA.
N
