RamVenture
I’m trying to identify if I have a small fuel leak. I’ve read of using UV dye to locate oil and fuel leaks. Wondering if anyone has used it with diesel fuel on their truck. What dye did you use and how much to add? I’ve seen some small uv dye that says it’s safe for oil and fuel. I was thinking to add with tank around 1/3 to ensure it doesn’t get too diluted. Checking around the injector tubes with my UV flashlight at night I’m getting some slight yellow/green shine. Im not sure if oil, diesel or both normally shines this color under UV light. It would be great if I could find an orange dye then I would if it’s fuel. Thanks for any advice.
