Engine/Transmission (1998.5 - 2002) Diesel fuel leak.....Please help to ID
Engine/Transmission (1998.5 - 2002) Synthetics
Engine/Transmission (1998.5 - 2002) 5spd shifter shakes?
Good evening! My 2002 is dripping a little fuel from the drivers side to the left of the oil pan. I took a picture and here it is. Leaving about a quarter sized drip on the floor under the truck... Is this the VP 44 area??? Thanks!! I am 3rd genner so not sure here...
If you want a 70$ stock lift pump call Steven at 901-345 3270. $70 plus shipping and he will ship anywhere. If you are going to change it out you might as well order the relocation kit and relocate it to the frame near the tank. My original lift pump is still producing 13 psi at idle and 9 at wot after relocating it to the frame with over 165K miles. I have a new pump to replace it with, cost 70$ from Steve.
Hope this helps.
Just another thought, before you spend money on a new pump. Check the water drain on the fuel filter housing. If you recently drained the water it may not have closed all the way and may be seeping a bit.
I agree with Allnew2Me. I had to replace mine at 95k, and the new one is leaking again. At $20, they're not expensive, but a PITA to smell the fuel. Easy to change too... just 4 torx bits.
