I recently (finally) had my injection pump changed under warranty. It has been approximately 2,500 miles since this was done, and 7000 miles (it's been really cold) since I changed my oil. I use Rotella T 15W40. When I drained the oil saturday, it poured out like black water. It splashed off my drain pan in every direction including my face and hands. It was not particulary warm. I immediately thought maybe the new VP44 is leaky so I just filled it back up with new oil and took it to the dealer. I also put a sample of the oil I took out into a glass jar, but the container I was draining the oil into was not clean so I'm pretty sure the sample was contaminated. The dealer claims they have no way to verify the leak or test the oil, and that the sample oil I gave them just looks like used oil to them. Additionally, neither I nor the dealer tech could smell any diesel in the oil. I contacted Geno's garage and subsequently ordered an oil test kit. I then contacted Fleetguard who performs the test and spoke with a tech there about some additional tests they can perform on the oil. The tech there also said that he has never smelled diesel in the oil because the smell of the oil masks the scent. The dealer recommended that I monitor the level of the oil and if it is rising, to bring it back and they will address it then. Can anyone recommend anything else to try or any other course of action? Should I be worried about driving the truck? I think diesel will just thin the oil, and cause wear by not sticking to parts it should, but will it cause any other harm? Any help truly appreciated.
Mark
2001 Dodge Ram 2500 4X4 Diesel
Mark
