I found out how much power the Cummins engine has 'stock'! I won't say I'm proud of what happened but it did happen. I hooked up the fifth wheel to take to the dealer for some work on the air conditioner. It is a 33 foot Cardinal and the GCWR is pretty close to the limit of 20,000 pounds. When I pulled out of the driveway the cable to the safety disconnect switch, evidently, got jammed under part of the fifth wheel hitch and it pulled the pin. That locked up the trailer brakes and I pulled it 4 miles before I saw the smoke coming from under the trailer. I shut it down, reconnected the pin and went on to the dealer. The engine did not even strain nor did the rear wheels slip.
I have the 2002 HO with 6-speed manual transmission. No power modifications made yet.
