"Diesel Secret Energy"
Fuelmeister bio diesel machine
I wanna make BIO DIESEL... HOW???
Have any of yall had any experience with "Diesel Secret Energy"?
I did a Dogpile search for "Biodiesel" and their product came up. I have briefly heard mention of it on TDR, but what is involved in using it? Their website seemed hesitant to tell what ELSE was involved in using their product, just that you could use "common products" which would cost around 30 cents per gallon of fuel, in addition to their product. Sounds tempting, as I want to set up a system to mix WVO with ULSD for use in my two trucks, my Liberty, tractor, mower, atv and welding machine. A "dual fuel" WVO system is not practical with so many different pieces of equipment. I want one fuel for all, possibly in a concentration up to 50/50 diesel and WVO. What do yall recommend? I have two 250 gallon steel tanks and a 200 gallon steel tank on a stand, as well as a 12 volt biodiesel pump. I need a filtration system and have a decent (consistent) source for WVO (soy) and a good fuel supplier.
Thanks for the help and information!
John
here you go:
https://www.turbodieselregister.com/forums/alternative-fuels/143059-dse-truck-04-05-ctd.html
as punishment for not searching, you MUST read the WHOLE post.
Read that post. I am not interested in what it does in the '04-'05 (or up) catalytic converter equipped trucks. The '03 down models are totally different animals when it comes to alternative fuels. I am more interested in what it does and what is involved an using the stuff than what it does in a particular (later than mine) model truck.
dse
Hello Dieselnut
the older trucks run better than the newer trucks on this
as of 3/19/08 we have put this fuel in
98 dodge 12 v ppump stock
2001 dodge 24v vp44 stock
2001 dodge 2vv vp44 with heated tank and fuel pump
97 ? chevy 6. 5 diesel stock
2004 dodge 5. 9 cp3 with heated tank and fuel pump . smarty
2005 dodge 5. 9 cp3 stock w smarty
2 other chevys 2003 and a 2007
2 other fords 1999 to 2003
1950 ? 2-71 detroit genset
some have cats some don't and some should :-laf
the older the diesel the better this fuel runs in them
please note this is only what I have put the fuel in I have talked to 30 people that are doing this and none of us have had any engine issues.
The 03 and 04 are the better 3 gens to do this to. also no cat on my 1 ton not sure about the rest.
the mix dse is using will work but the blend I have been mixing works better starts better and is running great in these trucks but the main thing about this is filtering and getting the water out of the oil.
cj hall
Diesel secret
All I want to know is how this system works?
What is the source of waste oil used?
Then you add their chemicals and you have instant fuel capable of being burned just as tradtional diesel?
What about gel or clout point for cold WX operation?
dse in trucks 04/05 ctd
hello
all the info one need is in this post
yes there is a bunch of people that dont think this will work but it does
cj hall
Dieselnut, CJ's 04 is the pre-cat 305hp Cummins which is exactly the same as your '03.
