Diesel Shop near South New Jersey
Turbo Actuator and Motorcity Mechanic Video
Tires, alignment, and rubbing
Anyone know a reputable shop in Southern New Jersey? I’ve given up trying to service my truck. The fuel rail pressure sensor is showing signs of starting to fail. I’ve attempted to change it and can’t get near it much let alone remove the lifting bracket blocking it. I’m also due for valve adjustment. My 05 had room to work. Not so much on this 2013.
I decided to give it another shot. Ended up pulling out the fuel rack. If you haven’t done this almost everything has to come off the top of the engine. Electric wise. Being I had the top opened up I went after the valves also. Lash adjustment was way out of spec max on the exhaust is .030” I had a few that were close to .040”
5.5 hours later and half a pint of blood it’s back together and even runs. Actually it’s now running smoother than it has in a long while. Whoever changed the location of the fuel rail pressure sensor from the on top like the 5.9 had to against the fire wall needs to get Flogged. Bad enough the cowling overhangs the engine. Job is done it’s Miller time might have to switch to Miller heavy from miller light after this job....
