Diesel Swap Info
More 73-91 Chevy to 6bt questions
727 to gen 2 t-case info
I'm Wanting to dive Into a couple of Cummins swaps My first Swap is going to be My 79 Chevy K20 I have the T-case and transmission, a 96'12valve with nearly a million miles (so I'm looking for some good rebuild info/parts), mounts ,crossmember,hydroboost,Dana 60 front axle,and Intercooler.
I still need a flywheel,bellhousing,clutch,exhaust,Turbo(s)
I have an 8. 3 cummins I wonder if it would fit ? if it will physiaclly fit what are the differances part wise to use it???
Just going to throw this one out there. Purchase a running vehicle to make the swap from. Piecing together all those parts on your first one IMO is very risky. What if you get a bum part? Youll be fighting your first custom install and the bad parts. Seems like the very LONG way around it. My . 2
I have a complete running 96' ex-cab 2wheel drive 3/4 ton that's gonna be the donor for the Chevy
I need a bell housing, Flywheel, clutch,new turbo, Exhaust. I have everything else ready to go in the truck.
I'd like some advice on how to set up my engine it's gonna be my daily driver/tow rig/Hot rod. I'd like to get some where around 400hp/1100ft-lbs and not have to worry about burning it up pulling my 15,000 pound trailer. my Engine Budget is about $4500. 00 to rebuild and mod Can this be done????
Also my truck has the 180hp P7100 pump can the pump cam be changed to the 215hp stuff??
Traded My 8. 3 for a 2001 2500 4x4 24 valve that was rolled with a bad frame and no transmission truck has 80,000 miles I'd like to P-pump this engine and find a NV5600 and mate it to My Ford NP 205
