RE: gear lube '03 3500 DRW. Manual says GL-5 synthetic 75W90. The Mopar fluid spec'd by AA isn't stocked by my local "dealers". I've found Shell Spirex S (synthetic) 75w90 GL-5 ( approved
for extended changes in Eaton, Roadranger and Meritor products) in 5 gallon pail for $90. plus tax. If the gear lube in question in not approved for extended changes in real trucks, why would you want to use it in your truck? My employer uses75W90 synthetic Tegra(Chevron) in a fleet of 2000 large trucks. However, the local distributor doesn't stock it. The shell distributor has his product in stock, so Shell it is. If you are towing, use an oil rated for work. (PLEASE: no flames about yours is better, etc. If it doesn't have certification for extended changes from Eaton,Roadranger, Meritor, Dana, etc. , don't take it out on me. ) If your truck is in warranty, change at the DC specified intervals NO MATTER WHAT gear lube you use.
Note: I am changing the rear lube at 1900 miles cause the dealer topped it off when I couldn't find any fluid. They used 2 qts of non-synthetic and added a friction modifier. Would have been ok for Dana rear, but wrong for AA. "Hey, we just sell 'em, fix it yourself!"
