Sorry no pictures.
Thought I'd share a little improvement I did over the weekend.
What led to the need - a few weekends ago I was givin the ol gal a few strokes of grease, when I came upon the rear u-joint I grabbed the shaft to shift my body a bit and I felt it move just a bit. Further examination revealed the cups were staying with the joint but the whole joint moved within the yoke? The straps had stretched. The memories of blown drive shafts in the old hot rod MoPars, that usually happened on the 1-2 shift, popped back in my mind. "Blasted darn MoPar couldn't use a u-bolt, had to come up with these stinking scrawny strap pieces of s_ _t"?!#@$%!
Anyway instead of just replacing the straps (why replace junk with junk?, right) I went to the parts house, explained to my buddy what I was trying to do and he pulled the correct strap to get the cup size and then looked for the corresponding ford (I know) u-bolt. BINGO!
You have to drill out the existing strap bolt holes on the yoke to the size of the u-bolt threaded ends, a bit bigger actually. Then a bit of finessing to widen the u-bolt is required to center on the two holes. Bing - that's it.
The kit (two u-bolts, lock washers and nuts) cost me $5. 50 and are made by Precision Universal Joint (made in USA), part number on the box is 330-10. Another smaller number on the box is 1099253-A.
If anyone is remotely interested in pictures let me know and I'll take a few snaps. To me this was no big bomb, just a piece of mind not having to worry about the shaft dropping out.
