Originally posted by fredflinstone
It's my understanding that the major difference's are the injector pump is slightly different internally and the pcm is different. I have also heard rumor that the injectors may be different but I have yet to pull the injectors out of my new High output so I don't know about that for sure yet. Cummins now sells a new pcm that brings the power up on the other motors to about the same leval thought if your just interested in the extra power. As for the 99 being a HO I'm not sure but I believe only the HO came with the six speed.
Seth
Originally posted by TxDieselKid
Does everybody really think it's all that from the last post? If so, how come I can go get the same ratings as an HO with the torques maxes ecm?
the part that REALLY screws up all up is that the VP44 on the HO has plungers that are 8cm, and 9cm on the NON-HO VP44's. Weird huh?
Originally posted by rkubicki
I am guessing that the torques maxes ECM has a more radical fuel delivery map than the stock Cummins HO ECM.
-Rob
Same ratings as the HO, and it's not says that it is for 5 speeds only. If the fueling map is the same as an HO then... ... . ?
Fuel System: VP44 fuel pump components changed to allow for increased fuel delivery.
Controls: new software instructing fuel pump to deliver more fuel.
Injectors: Changed to allow for increased fuel delivery.
Pistons: New design for higher 17:1 compression ratio-
Head: powdered metal valve seat inserts for improved Durability.
Flywheel: larger to match to larger diameter clutch for handling higher torque output.
Originally posted by JIM S.
My truck is 17. 5:1guess they had to lower the compression so they could raise it for the HO and make it sound all wonderful
Jim
Originally posted by LSMITH
[snip]
The ETH is perfectly suited to the 6 speed transmission, man it shines with the even splits!!!
Rob,
I'm fully aware of everything that they say is in there. But it's just kinda weird how even with all that stuff, it's 505ft. lbs, and the ECM uprate is also 505ft. lbs(I have never heard of a hp number for them)
Jim
It just seems like you are comparing apples to oranges here, Andrew, in this case a stock engine (HO) to a modified non-HO ... .
but when the HO engine is reprogrammed to deliver more fuel in a similar fashion to the TM ECM you will see the HO's numbers pull away again.
I'm probably going to ruffle some feathers on this one: The smaller pump and injectors on the HO really don't make a difference when both engines are under closed-loop control from the ECM.
-Rob
Rob,
I first posted a question on this thread. I wanted an answer from it, and had no intentions of turning it into a debate, sorry for that, I was just showing something I thought was intresting.
As far as compairing apples to oranges, how is there THAT big of a difference when the power level is so close? The different parts don't amount to a hill of beans if you ask me. Look at what is going on over in Vegas right now. The difference is none between the HO and the non-HO on the dyno when no drugs are being used. Jim Fuller(CUMMNTSTRKIN) posted a HUGE number with a non-HO, and so did the DD boys.
Now when you start talking about reprograming, are you talking about aftermarket fueling boxes? If so, it is a known fact that HO's will not respond to them as greatly as non-HO's do.
Ruffle some feathers? No way man, I'm way too friendly to take this stuff seriously.![]()
Andrew
P. S. Are we turning into Don_M, and Sled Puller(Gene) type argueers?![]()
