Difference between the Edge Products Comp, PE & EZ??
fuel pressure info/test
3.73 Gear option?
Just curious what the differences were between the Comp, PE, and the EZ from Edge Products. Which one is the best?
Thanks!
depends on what you want ...
ez connects to map sensor and bus connector and disconnects without a trace (read warranty friendly), lower power increase than the comp or regular pe .
pe connect to map sensor and pricks pump wire post electronics , big power gain . but a warranty voider and is dectectable in the ecm , so i'm told ...
comp is ez and pe rolled into one , not as big a power gain as the ez and pe stacked , but more adjustable and can be turned off completely , where the ez is always on .
all the above technically viod your powertrain warranty , if you get caught that is ... lol ...
