I needed more CFM than the stock filter provided since #8 plate was installed, as boost went from 21 to 32 PSI. Filter minder pulls down to 20+" H20 w/new stock filter. Ordered one from Mcmaster Carr, cylindrical with open ends, 8"O. D. X 11" long, 5 micron rated, polyester media. I fabbed alum. ends with a stainless "cage" inside to allow centering as well as end plate wingnut holdown. Results follow.
Before:
71* ambient temp
10 PSI boost
750* EGT (pre turbo)
Lots of smoke at "launch"
Minder pulls down to 20+" H20
After:
73* ambient temp
10 PSI boost
700* EGT (pre turbo)
Appears to be less smoke at "launch"
Minder pulls down to 10" H20
*These reads are also with "stomped" to max boost to check minder pulldown.
So I got more CFM, as shown by the minder but other than that little change. Mileage check will tell more.
Mike
Before:
71* ambient temp
10 PSI boost
After:
73* ambient temp
10 PSI boost
Mike
