Can one of these work? Way cheaper.
http://www.amazon.com/QTEC70-Electric-Exhaust-Cutout-Valves/dp/B003R2KS4G
Those valves, I suspect, are only designed to work against the nominal backpressure in the exhaust system - something less than 1-2 PSI. In an exhaust brake application, they would see pressures of 40-50 PSI across the valve. That takes a strong butterfly valve, shaft and actuator to work with that pressure differential across the valve.
Rusty
