That was a known problem with the 7. 3s. Caused by cavitation. The 5. 9 Cummins does not hasve this problem. Its not a sleeved engine and can probaby take a fairly large over bore. I bet a rebuild with asll of the above mentioned by Loaded 45 would run $4500 to $6500 and I'm jusdt guessing. A good shop who does this kinda work could quote a lot closer. If a few holes are damaged slighly and nothing else it could be rwepaired a whole lot less with a overbore,pistons and gaskets,fliuds etc. Might be able to do a inframe(not pull the engine)if there are still machinests who have a portable bore/hone machine like I used in the past. Real BIG equipment with piston and wall damage can't be moved or taken to a shop. There done in the field etc. Even pulling the engine would not be THAT bad on a Dodge truck and only repairing whats needed at that low(102k)mileage,Repair shops(dealers also)have changed. In the auto repair I've handled LOTS of Z cars in the past that were bored in frame,bearings only replaced etc. We did many a NISSAN SENTRA/STANZA/Z car with smoking,oil leaks,timing belt damage and only did a hone,rod bearings,rings and a in house valve job and seals. We didn't call it a REBUILD or REBUILT its was REPAIRED cheapr then the other terms with all partys knowing what was being done. Made many a parant smile when trying to get a child through college on a budget and the last shop tried to knock their brains in with a HUGE est. and a NEW or FACTORY reman engine etc. This engine could be pulled,crank removed,bagged and sent to any DECENT mmachine shop,get bored,pistons,rings a NORMAL min. valve look at seals etc. ,new rod and main bearings and put back togather and back in the truck in a somewhat short period(2 weeks?)and a min amount of money spent compared to even buying one of those salvage engines off e/bay.
