I'm installing a MagTec Differential cover on my 2001, 2500,
2WD, six-speed with the HO Cummins. Increases the lube
capacity to almost 7. 5 quarts. I'm refilling the rear-end with
Redline, 80w-140 gear lube. Owner's manual calls for that heavy
a synthetic when pulling a load, as I am. Two questions:
The instructions on the Redline jug and the salesman both say
that it is NOT necessary to add a friction modifier for the clutches.
I did have to add two bottles of the stuff before, when using
Mobil 1, 80w-140. Opinions please. Also, to install the larger
MagTec, I had to move the sway bar out by installing a spacer
on the right side and redrilling the holes on the left. Do you think moving the sway bar would have a negative affect on it's operation? Thanks for the help.
