Differential covers
OE style fender flares
Trans Temp Gauge Sensor Leak
Can anyone tell me where to get a polished aluminum high oil capacity diff cover for the Dana 80? They make 'em for my front Dana 60, but I cant find one for the rear. I thinking about going to the wrecking yard, pulling a factory one and having it chromed. I'd really like the higher capacity though! Thanks for the help.
99 4x4 black sport quad cab,5-speed,4. 10lsd,every thing but leather,5" suspension lift(chrome),3"body lift,38" Ground Hawg radials, 16. 5x12 American Eagle wheels,K&N filter. 4" exhaust and DDIII's next!
Snyder, Summit Racing sells a chromed (steel) OE Dana 60 cover.
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, PIAA Dual Sport 900 auxiliary lights and Super White bulbs, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Hitco/Geno's exhaust blanket, Femco/Geno's EZ Drain oil pan plug, Banks Stinger 4" dia. stainless steel exhaust system, plus many other trick modifications
Coming Attractions: BD "Medium Stall" TC, BD valve body, BD PressureLoc, BD trick modified front pump assembly, '00 Sport headlights, '00 Sport grille (I'll squeeze it in somehow)
'00 Polaris 6x6
Mag-Hytec from Geno's or May-Hytec. About 250+$. Checkout the banner ad for "Cover your rear".
Gts to go -- credit cards and checkbook packed -- Showdown today AGN!!!!
\\BF//
I think you won't find a nicer cover than Mag Hytec, am considering one myself. Will get from Genos.
Larry
Ram Rod
'96 2500 club cab 5speed 4x4 3:54 pacbrake combo gauge and most all factory options
35' holiday rambler 5th wheel
on order: '01 3500 quad cab SLT+ white/agate 6 speed 4:10 posi camper/ towing packages towing mirrors etc. etc.
Snyder,I don't think you'll find a better aluminum differential cover,plus the greater capacity you want than from Mag-Hytec,you can order it through Geno's garage in the TDR publication.
2000 qc Slt+pkg. ,6-speed,4x4 dually,all the right stuff
Snyder,
I was lucky enough the buy a Magnagaurd Dana 80 cover about 3 years ago. Older TDR subsrcribers will remember it. It was offered in polished aluminum and your choice of powercoat color. I choose polished. The salesman advised against it, saying they will tarnish very quickly. He said their clear powercoat didn`t work that well. Air bubble problems ect. So I got 2 cans of Krylon clear and sprayed it. To this day it still looks great. Don`t have a picture, wish I did.
2 things you may want to try. Contact Mag-Hytec and see if you can get one unsprayed with the black coating. You can probably polish & Clear it yourself. I don`t know how rough it would be. Maybe they polish them before the black is applied.
Magview is similar to the old Magnaguard. Call them and ask the same question. They offer a powder coat color called "ball burnished" not sure what it is.
I`m with you. Plain ole polished aluminum or chrome looks the best #ad
The phone # for Magview is 877-624-8439. See the advertisement in TDR issue # 26 page 127.
Mag- Hytec you can just email
Another option is to have the cover Powder coated by Jet Hot or Airborn. Their Aluminum ceramic coating is real close to polished aluminum & chrome. The finish is industructable. You couldn`t chip it with a hammer & chisel. The ceramic coating itself can be buffed/polished for more luster if desired. These headers below have the ceramic Aluminum coating:
This should give you some options #ad
Bill R
94 2500 SLT,4X4,5 Speed,3. 54 LSD... . Still looks brand new... .
[This message has been edited by HEMI®Dart (edited 03-19-2000). ]
