Differential, Install new bearings 2003 American axle
Turbo problem
Injector Harness
RPosey
Would some one with a shop manial send me a pdf file of procedure for rebuild.
Will the Dana differential spreader work on the American axle differential
Finally got around to watching the video, will watch the long one when I am ready. Thanks a lot for the information
Thanks a bunch. Is that a home made tool you are using to adjust carrier bearing preload?
Na, not even a tool, just a screw driver I push through the holes if the adjuster nut.
Preload is very little on this axle, the torque that can applied with my tool is plenty.
Thanks for you help. I have just now developed a whine. Seems to have come on fairly quickly. Cant tell much difference in pulling or coasting. I wonder if it is the tires, but don't believe so. Cant b that lucky. Do u have the torque required for pinion and total of pinion and carrier.
