I'm using Amsoil 75w-140, have MagHytec cover. I live in a hot climate and do a lot of heavy towing. The oil meets specs, dealers everywhere use it, I see no problem. They cannot give you a warranty problem over another brand of oil as long as it meets specs.
You might want to consider moving up to 75w-110 or 75w140 as Dodge has changed its recommendation from the 75w90. Plus Dodge is also recommending using the additive with the limited slips now. The Amsoil Gear Lube salready have the additive.
I was told 1 year ago when I purchased my truck that when it came to changing the diff oils to go up to 75w140. My dealership went out of their way to make sure I knew to go to the higher visconsity when I changed out my diffs. My last visit they again mentioned it as I am getting close to the 15K recommended changeout. What they don't know is that I changed it already at 5K when I installed the MagHytec cover.
There is a discussion over on
http://www.carsondodge.com/ regarding the diff oils and the recommended changes. Good info from TDR's own John Holmes.
CD
